Hydraulic oil mixed with the engine oil
   / Hydraulic oil mixed with the engine oil #1
Jim Benner
Lebanon, mo
John Deere 8430 Generation II Series 4x4 articulated, hydrostatic power / 7.6L 6cl diesel
I have a John Deere 8430 Generation II Series 4x4 articulated, hydrostatic power / 7.6L 6cl diesel and I have hydraulic oil mixing with the engine oil. I assuming that the hydraulic pump has blown a seal. Is there anything else that could cause this problem? How hard is it to change the hydraulic pump? Any idea about the costs? Thanks
Jim
   / Hydraulic oil mixed with the engine oil #2
The problem just maybe the front pump shaft seal.
If you are going to do the replacing, check the shaft where the seals is located for wear.
20ft Utility Cargo Trailer (A51572)
20ft Utility Cargo...
1950 Desoto Sportsman (A51572)
1950 Desoto...
KUHN SL124T LOT NUMBER 63 (A53084)
KUHN SL124T LOT...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2014 Dodge 5500 4X4 Bucket Truck (A53472)
2014 Dodge 5500...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2021 FREIGHTLINER...
