I might get laid out for this comment...but I had some water in my hydraulic fluid and wanted to remove as much as I could short of pulling each cylinder off and opening them up and blowing air through the system...
I raised the backhoe, found the hose that pushed it up and left it be. (it's under pressure) I went to the OTHER hose that now has very little fluid on that side of cylinder and loosened it so it was open to air. I then went to my controls (machine is turned off) and slowly lowered the hoe....which pushed fluid out via gravity of the side holding it up, sucking air in the other side so that when it was done, I probably had say, 90% of the oil out of that cylinder. I did the boom and dipper sticks like this, then went to the loader and managed to extract "a lot" of the fluid from there but I think I was more successful on the backhoe side.
Oil got pushed into the tank, drained all that out and refilled.
I might do another swap next summer to give currently new fluid time to work around and dilute everything that was left behind.
Then you have the hoses full of fluid, the controls with fluid... so I knew I'd never get as much out as I really wanted.
