Hydraulic PSI Question
   / Hydraulic PSI Question #1
jmolwitz
Fairfield Ct
Struck Magnatrac MT3000
My Friend Frank has informed me that to figure out the power of an individual cylinder I should multiply the psi X the bore of the cylinder . For example 1000psi X 6" bore = 6000lbs of lift . My problem is that this only accounts for 6 square inches of piston pressure . I would personaly think that one would take the bore size and multiply times pie=3.14 and then multiply times the pressure = 18.84sq inches X 1000 psi = 18840 lb of lift .
Is this an Industry standard that frank is talking about , I want to know where the other 12.84 sq goes :confused: In my mind the oil acts on the entire top of the piston , not just 6 sq in .
What do you guys think ?:)
   / Hydraulic PSI Question #2
To calculate the cylider's linear force you multiply the pressure times the area that the pressure is acting upon. In your case, the cylinder area is pi times the cylinder radius squared or 3.14159 x 9 square inches or 28.27 sq. inches. Times your pressure will yield 28,270 lbs of force.
So its even more than I thought:cool: Thanks Bruce :)
   / Hydraulic PSI Question #4
Tech help. Click below. Select Calculators, then Force and speed
SURPLUS CENTER TECHNICAL HELP
   / Hydraulic PSI Question #5
That's a great tech reference -- Thanks
   / Hydraulic PSI Question #6
JMOLWITZ, don't forget that the force generated by the pressurized
oil in the extend direction is greater than that in the retract direction.
The retract direction calculation requires that you subtract the cross
sectional area of the rod from the cross sectional area of the piston.
   / Hydraulic PSI Question #7
The hydraulic calculator mentioned above will figure both extended and retraction forces.
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2017 Chevrolet Express Box Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
2023 Globe Booster Flipaxle (A51572)
2023 Globe Booster...
1273 (A50490)
1273 (A50490)
2010 JOHN DEERE 1110E FORWARDER (A51246)
2010 JOHN DEERE...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
