Hydraulic pump and motor questions
   / Hydraulic pump and motor questions #1
Pooh_Bear
Platinum Member
Dunlap TN 25 miles north of Chattanooga
Early 1949 Ford 8N
I have a vertical shaft engine.
Can a hydraulic pump be mounted vertically to this engine.
Should it be direct driven or can it be belt driven.
I have a 46 inch mower deck.
What size hydraulic motor would it take to run it.
And finally, I want to mount this all on a frame
and use a hydraulic motor to propel it.
What should the specs be on this motor.
If you haven't guessed already I'm thinking of building
a riding lawn mower with everything powered hydraulically.
My big question for now is, can a hydraulic pump be mounted vertically.
Thanks.
Pooh Bear
   / Hydraulic pump and motor questions #2
I mount them upright all the time. Pump don't care as long as it's filled with oil.
I also like to run them off a belt. It gives some measure of protection like a shear pin and allows me to change a pulley it I want more flow or pressure.
Now before someone points out the pressure thing...I mean I have had pumps that would slip the belt before getting the pressure up to where I wanted it. A larger pulley on the pump solved this.
Take a look at your deck and see what kind of reduction the present pulleys provide as to speed needed for the deck. Most small engines run in the 3200 to 3600 rpm range. Be prepared to spend a lot on oil and carry it all around as well as some way to cool it. This is another can of worms but figure on 15 gallons or more.
   / Hydraulic pump and motor questions #3
Bob,
I'm wondering why you would need so much hydraulic fluid on one of these small machines. The reservoir on my Ford 4500 fel has only a 5 gallon capacity with its 23 gpm pump. It works quite well.
Butch
   / Hydraulic pump and motor questions #4
Consider the load cycle. On the 4500 it is intermittant where on the mower it will be continuous. Load = heat.
   / Hydraulic pump and motor questions #5
Yep...heat. Add another motor to move the thing and you'll be up to frying temp in no time.
Although I have never stopped to look at one,I imagine the golf course mowers have some pretty big oil coolers. The highway bank mowers have a big tank on the left side of the cab and that also acts as a counter-weight.
Oh...forgot all about this....another reason to run the pump off a belt on a mower is that if you hit something with the deck and that motor turns into a pump....you won't bust a crank on the engine. Ideally, you might wanna consider a shear pin or something like it on the deck.
   / Hydraulic pump and motor questions #6
Get a gear pump for powering the hydraulic motor on the mower. Take a careful look at the maximum rpm for both the pump and motor. The mower spindles typically turn pretty fast. Many pumps are rated to turn at 3600rpm. You will need a high rpm hydraulic motor like these listed here:https://www.surpluscenter.com/sort.asp?UID=2009081921305432&catname=hydraulic&keyword=HMHS
And the previous poster was right that you would need a substantial oil cooler with an electric fan to move air through it since ground speed is typically low.
Wow, a lot to think about. Didn't consider the heat issue.
Glad to know I can run it using belts and pulleys. Simplifies things.
It will still end up being bigger than a regular lawn tractor.
Mite as well add some extra capabilities while I'm at it.
Still haven't figured out how to get the variable speed to drive it.
All I can think of is one of those variable flow controllers.
Need to be able to just creep along, or as much as 10mph.
Pooh Bear
   / Hydraulic pump and motor questions #9
You're also gonna need either a rotary flow divider,a double pump or two pumps of you want to run the drive hydraulically.
   / Hydraulic pump and motor questions #10
You might want to get some specifics from the people on the hydraulic board. Wayne comes to mind at the moment. I found (but don't remember where) that you typically want 1 gallon of resivoir for each gpm of pump. This also serves to allow micro bubbles to work there way out of the oil (prevents foaming). I've found that working with hydraulics is pretty straight forward and interesting but v-e-r-y messy.
5 1/2 DRILL PIPE (A48992)
5 1/2 DRILL PIPE...
2011 Terex Fuchs MHL340 Wheeled Material Handler (A49346)
2011 Terex Fuchs...
MILLER CP-302 WELDER (A48992)
MILLER CP-302...
Pallet of (11) 10 Lug Misc Wheels (A48837)
Pallet of (11) 10...
2015 TROXELL 130BBL VACUUM TRAILER (A48992)
2015 TROXELL...
1975  CHEVROLET  C60 TRAFFIC TRUCK (INOPERABLE) (A48992)
1975 CHEVROLET...
