Hydraulic pump problem
   / Hydraulic pump problem #1
roxynoodle
Veteran Member
NW Ohio
Yanmar 1510d, 1950 Farmall H
I was unloading mulch from my trailer yesterday with my 1510D when I realized I was leaking hydraulic fluid. It is coming out of the bottom of the hydraulic pump where the 4 bolts are. I tried tightening the bolts but that only stopped one from leaking. And I broke another which should be fun to get out. Does this sound like just a bad o-ring down there or something else? Any advice would be appreciated! Thanks!
   / Hydraulic pump problem #2
Are you talking about where the line attaches to the pump or the bolts that actually hold the pump together?
Aaron
Parts@HoyeTractor.com
(940)592-0181
They are the 4 bolts on the bottom of the pump that connect the high pressure line.
   / Hydraulic pump problem #4
Probably a code 61 flange fitting, possibly a code 62, but that's usually 4kpsi and up. There is an o-ring on the flange. Get the broken bolt out, and get a new flange kit. These are readily available at any good hose/hyd shop. A new flange kit should be about 20 to 25 bucks and have a new o-ring in it.
Just wanted to let everyone know the problem with the hydraulic pump was as simple as a blown o-ring! I'm back to tractoring!
Zerex 50/50 Anti-freeze (A53117)
Zerex 50/50...
2023 LandHonor RB-14-72W 72in Rock Bucket Skid Steer Attachment (A51691)
2023 LandHonor...
1994 Trailmobile 51 ft. Dry Van Trailer (A53117)
1994 Trailmobile...
2017 Caterpillar D5 K2 LGP (A53473)
2017 Caterpillar...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
