Hydraulic pump shim
   / Hydraulic pump shim #1
Majortomsdz
Ct1021
Anyone know of a kit for a ct1021 or at least what pump is used/diagram.
Want to check current pressure and possibly increase a tad.
   / Hydraulic pump shim #3
For the CT1021, the pump is likely a gear pump, but exact specs might vary depending on the year/model. You can grab a pressure gauge kit online or from your local hydraulics shop to check it. If you’re thinking about cranking up the pressure, just remember—more isn’t always better unless you like fixing blown seals. 😉 A service manual or diagram from your dealer should have the adjustment specs. Good luck dialing it in!
WOODS DHS48N LOT NUMBER 75 (A53084)
WOODS DHS48N LOT...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
HYDRAULIC SKID (A52472)
HYDRAULIC SKID...
2019 FORD F-250 (A52472)
2019 FORD F-250...
2007 DOOSAN G80 GENERATOR (A52472)
2007 DOOSAN G80...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
