Hydraulic Question
   / Hydraulic Question #1
Little Butch1
I have an L2800 Kubota and the hydraulics won't work.They were doing fine and I shut off the engine and now the bucket and mower won't work.I changed the filter,but still won't work.Any ideas ?thanks so much
Butch
   / Hydraulic Question #2
Welcome to TBN:D
Two things to check:
-That your rockshaft lever is centered (the lever that controls the 3PH)
-Unplug and re-seat any and all QD's (quick disconnects) on the hydraulic lines, especially if you have a backhoe plumbed.
Short of that, you will need to get a gauge and see if the pump is working.
Does the engine sound like it is under load? Any squealing noise?
Problem is solved.There was a cut in the hydraulic air return hose.We replaced the hose and everthing works great.I have heard this is a common problem on Kubota L2800 tractor.Thanks for your help KennyD.
   / Hydraulic Question #4
You are welcome, glad you got it fixed up:thumbsup:
2008 CATERPILLAR 272C SKID STEER (A51246)
2008 CATERPILLAR...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
MONOSEM NG-3 LOT NUMBER 262 (A53084)
MONOSEM NG-3 LOT...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
1266 (A50490)
1266 (A50490)
