Hydraulic question
   / Hydraulic question #1
ideburger
Batesville, IN
Ford 861
I have a leak in my hydraulic pump on my Ford 861. After disassembling, I found a tear in the inner cover gasket. I will try to find one locally tomorrow, but in case I am unsuccessful, I would like a plan B due to predicted snowfall (I need my tractor, loader mounted plow so I don't need the 3 pt).
Is there any issue with running the tractor without the hydraulic pump? Not that I could think of, but thought I would run it by you all. I would put something together to cover where the pump mounts to the tractor at both the engine and manifold. Will it work?
   / Hydraulic question #2
poor choice as you have tubes open.
Why not just replace the gasket?
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51694)
2017 John Deere...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2011 Toyota Sienna AWD Van (A51694)
2011 Toyota Sienna...
