Hydraulic quick couplers
   / Hydraulic quick couplers #1
CasCar
cat 268b
Has anyone bypassed the couplers and hooked it direct, just wondering if you can gain anymore flow to the head, on a s300 bobcat running a magnum mulcher.
   / Hydraulic quick couplers #2
Never have, but I want to. I'm sure you would pick up flow, but more importantly you won't be replacing those expensive couplers all the time. Its on my list, but not the top. If things ever slow down I may get to it.
   / Hydraulic quick couplers #3
I don't think you will pick up enough flow to justify taking away the versatility of being able to swap attachments. I ran mulchers on two s300's and got 37gpm on the flow meter.
I couldn't see much more coming through with the couplers bypassed. Without couplers, it would be difficult to hook up a flow meter to test unless you owned one and could modify it's input and output lines.
   / Hydraulic quick couplers #4
With a well designed coupler (which I assume they are), you don't lose much flow capacity. Although the coupler may have a small passage, it isn't very long. The flow loss is related to the velocity squared and the length. If the flow area is reduced to 1/2 the hose size for one inch of flow length in the coupler, the loss could be as small as adding 4 inches of length to the hose. It may not be intuitive, but you will gain a lot more by increasing the diameter of the hoses than eliminating the coupling, unless you are already pump flow limited.
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 31'' (A53002)
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
