Hydraulic quick disconnect for a snowplow leak
   / Hydraulic quick disconnect for a snowplow leak #1
marshallcro
Stanfordville,ny
John Deere 3720, Farmall Cub, Bobcat 3400
Could you please tell me if a female hydraulic quick disconnect fitting for a snowplow can be repaired in an emergency by wire brushing any corrosion or rust in it or is replacing it the only option. Thanks in advance..
   / Hydraulic quick disconnect for a snowplow leak #2
It's the O ring that needs to be service in all probability. Can you eliminate the disconnect by hard fixturing it if that gets you back in business ? Ordinary pipe couplings will work.
   / Hydraulic quick disconnect for a snowplow leak #3
I always kept two lines with fittings behind the truck seat. When you or someone else is plowing parking blocks or curbs put a lot of back pressure on the hoses. Lines always get blown at 3 am in the morning with snow still coming down. Pipe fitting idea is a good one.
1271 (A50490)
1271 (A50490)
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A51039)
2012 Freightliner...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
