Hydraulic Spool Valve Sticking
   / Hydraulic Spool Valve Sticking #1
Silvic
West of no-where
I have a piece of equipment that has two sets of spool valves with a bank of six on each. One of the banks of SV's has a valve/lever that is a bit prone to sticking and has to be manually returned to the neutral position. I have wondered if there is some kind of debris caught in the valve but it does not seem to pass. Never had this before and am not certain what the troubleshooting tree should be. Any of the hydraulic gurus got a direction for me to start looking. The valve seems to function normally otherwise except it tends to stick in both forward and aft positions and does not return to neutral.
   / Hydraulic Spool Valve Sticking #2
I assume this is a "stack" valve, one that has multiple sections bolted together with long bolts? It could be that the bolts are to tight, or tightened unevenly. Perhaps it was leaking a bit at one time and someone tightened them to much rather than replacing the o-rings between the sections.
   / Hydraulic Spool Valve Sticking #3
You can remove all the parts to that spool section and see if there is any debris.
Check springs and parts on the bottom of the spool section.
With all parts removed from the spool, slide the spool in the bore and see if it slides freely, and if so, look closely at the parts, especially the springs and washers.
There are torque specs for the valve.
No it is not a stack valve. One piece with 6 SV's
Never taken one apart but looks like there may be a first time coming soon. :D
Any techniques or things to watch carefully for beside not losing parts and reassembling with correct torque values?
   / Hydraulic Spool Valve Sticking #5
Do you have an illustrated breakdown of the valve?
On the bottom of the valve, thee are springs and washers, and if you have float, there are little springs and balls in the assembly.
Could that sticking spool be a detent spool, one that is supposed to stay in detent.
   / Hydraulic Spool Valve Sticking #6
OK, one other simple thing to try: Loosen all the mounting bolts and see if it still sticks. Perhaps, if your lucky the surface its bolted to is not flat and the valve body is ever-so slightly twisted. It's worth a try...
   / Hydraulic Spool Valve Sticking #7
I had that problem once and I was on the way to taking everything apart and found it was in the pivot for the handle. Big relief.
   / Hydraulic Spool Valve Sticking #8
Does it stick when there is no pressure? My 7520 loader curl sticks only when theres pressure - the more pressure the harder to return to neutral. I know the valve was damaged somehow by overpressure by pushing a stump bucket with the valve centered - no relief in this situation so pressure can go sky hi. I assume the spool is damaged but I havnt investigated. Like yours, the valve functions fine but just has to be manually centered.
Yes it sticks with no pressure on the system.
I have found that if I move the valve back and forth multiple times (10-20) it does seem to get better but if left alone it always starts sticking again.
2014 FORD F150 4X4 CREW CAB PICKUP TRUCK (A52576)
2014 FORD F150 4X4...
Two Post Car Lift (A50120)
Two Post Car Lift...
6x14 Double Axle Bumper Pull Trailer (A51572)
6x14 Double Axle...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2003 CATERPILLAR 277 SKID STEER (A51246)
2003 CATERPILLAR...
