Hydraulic Troubles
   / Hydraulic Troubles #1
mbandrlb
Hoschton,Ga.
.Mitsubishi MTE1800FD
Hi all,
I recently picked up an early 70's model Deutz D4006 from a estate sale.It came with several attachments.one being a front end loader.I put the loader on and it works ok,except it seems to raise and lower unevenly.It seems to favor the right side.Someone has mentioned I may need to install some kind of a equalization valve to allow both sides to work evenly.This loader is definately a backyard mechanic assembled piece.
any and all ideas are welcome.
Thanks,
Mike
   / Hydraulic Troubles #2
Maybe one cyl is binding.
If you remove both cyl rod ends from the bucket, you can extend and retract the cyls to see which one is not working correctly.
I will give it a try.
All hydraulic parts were new,which is why i bought the tractor.Just sat around for a few months waiting on the estate to be finalized.
Thanks,
Mike
   / Hydraulic Troubles #4
I think you may have a lazy cylinder, as in one is doing the work and the other is only doing half the work.
This is due to one of the cylinder's bypassing fluid.
Solution:
Reseal the bypassing cylinder
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
1261 (A50490)
1261 (A50490)
GENERATOR (A53843)
GENERATOR (A53843)
Electric Mobility Scooter (A51694)
Electric Mobility...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
