Backhoe hydraulics 3500a
   / hydraulics 3500a #1
freeman5
mantague,calif.
international 3500a
i got a ih 3500a backhoe form a friend and changed the trans. filter because trans. wasn't working right and then lost the hydraulics. i can hardly get the bucket to raise and the hoe and the leggs dont work at all. when you try to lift the hoe you can see it try and then it stops and looks like it goes the other way. the bucket has a hard time going up, doesnt go up all at once have to work at it. you can rool the bucket but has no power. i put tractor hydraulic fluid in it because it has a hydrostatic transmission in it and i was told that thats what it took. does anyone have any other ideas that could be wrong. thanks
   / hydraulics 3500a #2
I was told that if you mix two different hydraulic fluids together they will not work properly..... Try draining all the hydraulic fluids out and refill with only one type it might work good luck.....obb
   / hydraulics 3500a #3
It sounds like the flow divider has stuck or is air bound, this can happen if you shut it down low on fluid and when you start it back up and the hydraulics go haywire. You have two hydraulic pumps and this combines the two.
some of the hydraulics run on high pressure and some on low. On the bottom side of the gear case/hydraulic reservoir there is a big plug, not the drain plug but a flat plug that has an o-ring seal on it. With the motor off pull the plug and see if there is a spring and a small spool. If so you need to have someone turn the motor over it can run at a slow idle until hydraulic fluid comes out, put the spool and spring back in, it can be a little messy. When air gets in the system it happens and this is the only way I have found to get it going
2018 Land Rover Range Rover Supercharged 4WD SUV (A50324)
2018 Land Rover...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
1986 GMC Top Kick Grain Truck (A50514)
1986 GMC Top Kick...
UNUSED JCT SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED JCT SKID...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
