KBKubota
Hi I am new to this forum but have read quite a bit here. I have what should be a simple problem but dont know answer. Just bought used m9000 tractor put 20 hours on tractor prepping for planting food plots about twenty five acres . waiting on coop to put fertilizer out so I had downtime I changed engine oil no problem. I had noticed hydraulic functions slowing so I decided to change fluid and previous owner had sent spare filter with tractor it was my intention to change fluid and filter and if helped at end of season change again with synthetic kubota fluid so i bought cheapest fluid not kubota. I drained fluid out both compartments. specs call for about 13.7 gallons fluid got little less than that out. then went to change filter and when found it in front of rear axel right side there were two(I know I should hav checked first). Being easter sunday I couldnt get another filter auto stores here didnt have one dealer and napa closed so I decided to put new one on what I thought was primary so I put it on position toward the front. Then I decided to remove other filter to drain as much dirty oil out as possible. when I took it off there is some type of apparatus that projects into the center of the filter that is about a quarter inch diameter rod about 3 inches long that has what looks like a john boat plug on the end, this had a lot of thick material on it which I wiped off. I then replaced the old filter. When refilled fluid may have overfilled a little. I restarted tractor and no hydraulic functions will work, no transmission 3 pt pto or rear hydraulics. I let the tractor run about ten minutes hoping air needed purging no help. Is ther some reset switch or did I need to do something with this apparatus or do you think the second filter is now totally stopped up? Any help appreciated sorry for the long post, plan to get another filter today and replace it if fluid doesnt leak out much. Add: It has hydraulic shuttle transmission.
