Hydraulics for log splitter
   / Hydraulics for log splitter #1
Lobo 38
Massey Ferguson 1215
I have a Massey 1215. I want to attach a log splitter to it this fall.There are quick connect attachments on 2 of the hydraulic hoses. Will these work to connect to the splitter? What else will I need to know? I am new to the forum. Thanks for any help.
   / Hydraulics for log splitter #2
The 1215 has just under 5 gal per minute hydraulic flow. That's sufficient for most splitters, especially if a two stage pump. It depends on the condition of your hydraulic pump and the size of your remotes. All quick connects reduce flow, but not significantly. If the remotes are the tiny Japanese size, you may have a challenge finding ends. At worse, if the pump isn't performing and the remotes are constricting, the splitter will run a bit slower.
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
1991 HEIL FUEL TRANSPORT TRAILER (A52472)
1991 HEIL FUEL...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646718 (A51572)
2013 Dodge Charger...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
2005 FORD F-650 (A52472)
2005 FORD F-650...
