hydraulics went dead
   / hydraulics went dead #1
dirtydigger
Hi, Im new to the forum and a brand new owner of a 863 bobcat, anyway, I was running it today for a bit and all the sudden the hydraulics just quite on me, I had a look at the hydrostatic fluid dipstick and it was empty.
It looked like there was fluid spilling out of the fill cap area because there was fluid around the hole and a stream running down the side of the bobcat.
So Im assuming and hoping that all I have to do is fill up the fluid, it looks like it holds about 15 litres, is it possible that the fluid emptied out of the fill cap area, and what damage could have been caused from that.
Any help or tipas would be great, thanks
   / hydraulics went dead #2
Well, you would normally get some suggestions from all the knowledgeabe folks here. I don't have an answer for you, but if something is causing your oil to blow out the filler cap, refilling it will confirm it.
Welcome to the board, I hope you have a long and enjoyable stay.
Keep us informed on the solution to your problem
all fixed , had a leak in the filler cap of the hydro fluid so I ran out and everything went dead, filled it up and away I went,
   / hydraulics went dead #5
As you are probably aware, the breather hydraulic fluid caps have a limited life span of 500 hours and should then be replaced.
Steve
Its my first bobcat which I have only had for about 3 weeks so Im a true begginner and still hava allot to learn, can anyone help me on the steering linkage problem that I have, the hand controls are unequal so it wants to go to one side, I hope its a small fix that maybe I can do myself
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
