Hydro filter question
   / Hydro filter question #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
Does anyone know if WIX or Napa makes a filter replacement for the BX hydo filters and screen? I was looking at comparisons for the oil, air, and fuel, but nothing for the hydro filter.
   / Hydro filter question #2
I don't know if the BX filter has a magnet at the end to catch metal filings like the L4400 does. But the replacements for the L don't have the magnets so I use the Kubota filters with the magnets.
   / Hydro filter question #3
From what I learned it appears that the hydro/transmission filters are propriatery to each mfg.. On my JD I has the Donaldonson filter number (and the JD part #) and I could not get either to cross over to a wix or fleetguard filter.. As you found out there appear to be crosses for all the other filters though..
brian
   / Hydro filter question #4
Does WIX or Napa have any advantage over the Kubota filters? Does anyone know what specs are set for the Kubota OEM filters?
Thanks, rScotty
   / Hydro filter question #5
If you go to Wix filters .com and use filter lookup you may find them. It uses drop down menus to locate each Kubota model. Once you have a filter number you can then get all the specs on the filter including micron rating.
We use Wix exclusively when possible at our City fleet where I work whenever possible. We have Kubotas, Deeres... along with patrol cars and large trucks. Never a problem.
On my personal L3400 HST I will be using geunine Kubota filters as I also use Motorcraft on my Fords and Honda on those cars. That is just my personal choice on my own vehicles.
1041 (A50459)
1041 (A50459)
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
Swamp Buggy (A49346)
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
71061 (A49346)
71061 (A49346)
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
