Hydro Pedal Sticks
   / Hydro Pedal Sticks #1
Hammsman
IA
John Deere 2320
Our 2320 hydro pedal sticks in high range only if pushed all the way down going down a road for 10 min. Does not stick is not pushed all the way. In low range NEVER sticks pushed all the way. Is the Hydro buliding pressure or something? Again in low range never a problem, high range only a problem if push ALL the way for long period of time. NEVER a problem in low range. All linkage checked and lubed. Thanks for any help.
   / Hydro Pedal Sticks #2
I'd say to have the dealer check the pressures on the hydro. It should not be sticking!
1265 (A50490)
1265 (A50490)
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
2021 CASE 580SN WT (A47477)
2021 CASE 580SN WT...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
7046 (A50322)
7046 (A50322)
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
