I bought a used 2420 farm pro tractor. I need to know what a filler cap goes to
   / I bought a used 2420 farm pro tractor. I need to know what a filler cap goes to #1
ineedhelp
Church Hill, TN
2024 (year-2003) Farm Pro, A 370-D Satoh Beaver
[/SIZE]:confused:The filler cap is located on the left side of the tractor engine if you are sitting on the tractor it is at the front left side of the engine. The filler cap has red paint on it. It looks as if it is a steering pump but I am not sure. I don't know if the red paint on the filler cap means that fluids are not put in it? Can someone help me out? I don't want to do something like put something in that should not be in there.
   / I bought a used 2420 farm pro tractor. I need to know what a filler cap goes to #2
Sounds like the injector pump. Mines a 204 and the injector pump is on the left side roughly mid height of the engine. There is a drain on the bottom, fill on top and a 90° fitting with a plastic plug on the front of the pump which is the oil level. The oil, (engine oil is what I use 15W-40) is poured into the pump till it comes out the overflow which gives you the corrrect quantity. It's slow as the pump has two chambers and one fill so the oil has to travel from one side to the other.
Peruse around here CHINESE TRACTOR OWNERS CLUB FORUM - Home a bit, good bunch of guys (same as here) but more geared toward Chinese tractors...Mike
Thank, I will check it out. I didn't want to put a wrong fluid in it. Thanks again.
   / I bought a used 2420 farm pro tractor. I need to know what a filler cap goes to #4
I have a Jinma 284, your tractor is a Jinma rebadged. The cap you speak of is for engine oil for the motor, not the injection pump.
Go to the Chinese section and you can get tons of help with pictures, ect .
Chris
   / I bought a used 2420 farm pro tractor. I need to know what a filler cap goes to #5
You sure Chris, ......left front side of engine, .....It looks as if it is a steering pump. http://tinyurl.com/6q8suvx
The engine oil fill is on the top center of the engine, on the valve cover, least on mine it is.......Mike
It is the engine oil filler. It had me confused as there is also a filler cap on the valve cover. Thanks for the help.
   / I bought a used 2420 farm pro tractor. I need to know what a filler cap goes to #7
Many machines have multiple engine fill points. Same engine can be used in multiple applications and it is less expensive to keep a common valve cover than provide multiple designs and absorb the tooling cost. My Kubota has a recommended side fill but the valve cover plug is easier to pour oil in.
   / I bought a used 2420 farm pro tractor. I need to know what a filler cap goes to #8
Glad you got it figured out. What thru me was when you sadi it looked like a power steering pump so I visualized a separate unit, alls well that ends well :) .....Mike
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2019 INTERNATIONAL...
2022 Polaris Ranger Utility Cart (A53421)
2022 Polaris...
2018 John Deere 1653 (A55302)
2018 John Deere...
2013 Chevrolet 3500HD MPV Service Truck (A52377)
2013 Chevrolet...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
