I figured out what I want, pto 50-65hp Diesel. 2wd or 4wd, FEL? $10,000
   / I figured out what I want, pto 50-65hp Diesel. 2wd or 4wd, FEL? $10,000 #1
joe t
Houston Tx
1900 Ford
I posted on here about needing to do some brush hogging.
Figured out I can get a mower I need used for around $3,000. It is a Brown and needs at least 50hp PTO and I believe up to 140hp.
Tree Cutters | Brown Manufacturing | 800-633-8909
Recommend some tractors. Maybe I can redneck rig the FEL off my current tractor on the new one...
4wd is cool but I could live without it. Think I would regret not having it but could live without it.
I kinda like this one:
http://www.tractordata.com/farm-tractors/000/0/8/85-john-deere-2030.html
   / I figured out what I want, pto 50-65hp Diesel. 2wd or 4wd, FEL? $10,000 #2
Joe,
Which Brown cutter are you looking at? If your looking at the rotary cutter's then you would be fine at 50-60pto hp, but if your looking at the Brown Tree Cutter's, you really need more PTO hp and certainly some sort of forestry cage around the back of the tractor, as well as top. Also, those Tree Cutter's are HEAVY! You need a substantial tractor for them.
What size trees will you be cutting with the mower?
4-6 inches. Most will be laid down already.
I am also looking at the JD4020 which is like 90-100hp.
   / I figured out what I want, pto 50-65hp Diesel. 2wd or 4wd, FEL? $10,000 #4
You should be able to get a JD2030, diesel with a loader for $10,000
Pretty good tractor? I think they look cool. Now I need to save some money up.
   / I figured out what I want, pto 50-65hp Diesel. 2wd or 4wd, FEL? $10,000 #6
I've had mine 19 years. HI-LO is a weak link. I had to repair mine 12 years ago, not cheap to fix, may want to avoid HI-LO.
Since you want a loader, make sure it has the HD front axle.
UNUSED IRANCH 16" EXCAVATOR RAKE (A54757)
UNUSED IRANCH 16"...
2007 International 4400 2,000 Gallon Water Truck (A52377)
2007 International...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2021 Allmand Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand...
2021 CATERPILLAR 908M WHEEL LOADER (A52705)
2021 CATERPILLAR...
