I have 1864 cub cadet with CH18 kohler, I think flywheel end oil seal is leaking
   / I have 1864 cub cadet with CH18 kohler, I think flywheel end oil seal is leaking #1
etap
louisville
iz4818 zero turn husqvarn & 1864 cub cadet
My cub cadet only has 640 hrs, and I am finding oil under the engine. If that seal is bad,can I remove drive shaft and metal and change it, without pulling the engine. Would it be better just take the engine out,to change the seal. I have found alittle oil at valve covers,and replacing gaskets today. I alway change oil every spring, and fall cutting 3/4 of acre. Would useing synthetic oil cause this. Another guy told me to put a balloon on the dipstick tube,to see if it has pressure in the crankcase,it should be in a vacuum.THX
   / I have 1864 cub cadet with CH18 kohler, I think flywheel end oil seal is leaking #2
I don't think you will have room to remove the blower housing and flywheel to get to the seal without removing the engine. This assumes that you are talking about the flywheel/ magneto seal, as opposed to the pto seal. Something that I come across very often is most newer engines have that 1/4 turn and pull oil drain, that are really common to have leak problems.
I just wanted to thank you all. I think that my oil leak was valve covers, and oil from hydro. lines on the power steering behind the engine. I think I was very lucky, not having to pull the engine. Thanks again!
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
FORD 7600 TRACTOR (A51243)
FORD 7600 TRACTOR...
John Deere 970 Cultimulcher (A52128)
John Deere 970...
2006 Cat 963C Crawler Loader (RIDE AND DRIVE) (NICE) (A50774)
2006 Cat 963C...
