I have a 2003 Deere 4310. I need help diagnosing a starting problem. I turn the ignition, dash lights come on, then it goes blank.It has a new battery
   / I have a 2003 Deere 4310. I need help diagnosing a starting problem. I turn the ignition, dash lights come on, then it goes blank.It has a new battery #1
TCLONG1030
John Deere 4310
I HAVE A 2003 DEERE 4310. I NEED HELP DIAGNOSING A STARTING PROBLE. I TURN THE IGNITION, DASH LIGHTS COME ON, THEM TURN TO START AND GOES BLANK. I BOUGHT A NEW BATTERY, CHECKED THE FUSES AND REPLACED ONE 20 AMP FUSE. BUT DOES THE SAME THING. TRACTOR IS IN NEUTRAL AND PTO IS OFF. THERE WAS A NEST BEHIND THE DASHBOARD AND CLEANED IT OUT. LOOKED FOR FRARED WIRES AND COULDN'T SEE ANY. COULD IT BE A FAULTY FUEL SHUTOFF SOLENOID? WOULD A BAD STARTER MOTOR CAUSE THIS? WOULD APPRECIATE ANY IDEAS.
THANK YOU
TCLONG1030
   / I have a 2003 Deere 4310. I need help diagnosing a starting problem. I turn the ignition, dash lights come on, then it goes blank.It has a new battery #2
Hit your CapsLock, OK?
What else happened, or didn't before you noticed the problem?
Check all of the grounds from the battery to the starter and frame. Both ends. Pull them and clean them, then reseat tightly. Symptoms indicate a loss of power under load which could be a bad ground.
   / I have a 2003 Deere 4310. I need help diagnosing a starting problem. I turn the ignition, dash lights come on, then it goes blank.It has a new battery #3
That's when it is handy to have a cheap load tester you can attach at the starter. My bet is a bad connection as well. Did you clean your battery terminals with a cone chaped wire brush?
   / I have a 2003 Deere 4310. I need help diagnosing a starting problem. I turn the ignition, dash lights come on, then it goes blank.It has a new battery #4
Welcome to TBN
I'll suggest to clean/tighten battery ground cable where it attaches to tractor frame.
2008 Ford Focus Sedan (A55758)
2008 Ford Focus...
2008 UTILITY VS2DX DRY VAN TRAILER (A54607)
2008 UTILITY VS2DX...
Ford F450 Bucket Truck with Altec AT200A Boom (A55218)
Ford F450 Bucket...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
