Need to know what causes it to jerk while starting in low gear it also squeals when turning. Fluid is fine, new filters could this be a linkage problem and if so how do you fix it. THANK YOU:confused2:
Ford 7710, Ford 550, Ford 1910, Ford 4430, KD Forklift, Ford LGT17H, New Holland L255 Skidsteer
When you say it jerks in low, it jumps or lurches forward but not reverse? Is throttle at idle, ie: 750-900 rpm?
Steering is squeeling while just turning or when it is turned against lock? Squeeling from pump? All the time?
