SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,393
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Im sorry I didnt focus on the pump issue sooner. Youve learned empirically what the numbers would have told us up front, had we looked at them. Your altitude has atmospheric pressure equivalent to about 29' of water. With your raised well head you have a lift requirement of 21.5'. With this 7.5' margin a siphon would work. Your pump has 26' lift at sea level. Reduce this by 4' due to your elevation and you have a nominal lift capacity of 22' - - a 0.5' margin. So, with the pump you are at the theoretical limit of possibility to be able to get the water over the top. You may have tried during a period of low barometric pressure which would have made it worse. If it had come over you would have been able to establish the siphon. With the downwell pump you plan, it would be fairly simple to keep the siphon option open. Just put a zero pressure cracking check valve in the pipe right above the pump. Once the pump fills the line it could be turned off and the check would open and allow the siphon to pull water.stumpfield said:I spent a week off and on trying different things. I put more water into the well than I got out of it. Even with a check valve at the bottom to keep the suction hose full of water and the pump primed. It just can't pull water up that high and so close to the practical limit. After adding all the variables, I'm very close to that limit. I'm at about 3000' elevation. The well casing is another a foot and a half above ground plus all other inefficiencies. I decided to go with a solar pump. Grundfos SQfelx 11 Helical Rotor pump. It's a very expensive pump but very flexible and able to take 30-300v DC and 90-240v AC.
Larry
