3-Point Hitch I have a TN70 and the position control lever is stuck. It wont move up or down. Any suggestions on how to fix it?
   / I have a TN70 and the position control lever is stuck. It wont move up or down. Any suggestions on how to fix it? #1
Hopewell
New Holland TN70
   / I have a TN70 and the position control lever is stuck. It wont move up or down. Any suggestions on how to fix it? #2
Can you follow the lever all the way down? Usually there are some friction washers there along with a big spring and two studs with nuts. By adjusting these nuts, you can adjust the friction on the lever.
   / I have a TN70 and the position control lever is stuck. It wont move up or down. Any suggestions on how to fix it? #3
This or the cable from the lever to the control is rusted and needs to be replaced
5-ton Military Axles (A44391)
5-ton Military...
Mini Excavator Hydraulic Breaker Attachment (A45336)
Mini Excavator...
MLE 4188CR Clean Room Scissor Lift (A44571)
MLE 4188CR Clean...
2012 Isuzu NPR Truck, VIN # 54DB4W1B4CS803964 (A44391)
2012 Isuzu NPR...
2019 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A45336)
2019 Peterbilt 389...
2014 Therm Dynamics TD400 Towable Flameless Heater (A45336)
2014 Therm...
