I have this old tiller implement
   / I have this old tiller implement #1
prs
Platinum Member
Logan, WV
JD 650, Ventrac 4500Z AJ02248
I a 4' PTO tiller that has worked great even though it is greatly worn. I have misplaced the female end of the PTO shaft, the end that attached to the tractor. I need to search for parts, but to save me I can not recall how to SPELL the maker's name. It is something like KARONE or CARONE or CARONIE or KARONIE or ??????? Fairly common, but I can't get it close enough to get search to find it or even google to suggest.
prs
   / I have this old tiller implement #3
Fortunately for you drive lines are drive lines. Once the appropriate category and shaft style has been found, all the parts interchange regardless of who you get them from. The avg parts house will need to know accurate measurement of the brg cross (cap dia and width - so take one apart if you can) as well as either style of tubes and possibly measurement of the tubes(or just bring them the imp 1/2, tell them what pto size you need) and away you go. In many cases a complete drive line all the way to your tiller is better priced than a 1/2 shaft from an oem. Good luck
Thanks, I have it covered now.
prs
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
