I need PHD
   / I need PHD #1
lakngulf
Veteran Member
Lake Martin Alabama
Kioti CK30
I need a PHD, not the education kind but the kind to dig holes. Is there a place to find them used down in my area? Will need 12 inch auger I think.
   / I need PHD #2
Bigger is better. With a 12 inch auger, I don't have to be as accurate drilling holes, the wiggle room helps.
   / I need PHD #3
The most important thing when looking at post hole diggers is the tip of the auger. Most of the rest of them is all pretty similar and basic. I have a Leinbach Line that came with a pretty poor auger. I replaced it with a Country Line auger that has replaceable teeth and tip that is just amazing. It cuts through the hardest clay easily.
Tractor Supply sells them and for the most part, I don't like Tractor Supply, but I love this auger and highly recommend it.
I've only had a 12 inch and wouldn't want one any smaller. Getting holes lined up in a straight line, and then drilling them perfectly straight, and having them remain straight as you go down is just about impossible if you do more then two holes in a row. Having a few inches to line up you post makes a huge difference. Even with a 12 inch hole, it's not uncommon to have to dig a little with the clamshells to get it just right.
Eddie
   / I need PHD #4
I have a 12" auger County Line (same model as Eddie)...no joke, if you don't watch it, it will suck the tractor down the hole after it..I was amazed at how fast it digs and I only use it just above idle speed. Good unit. BobG in VA
   / I need PHD
Tractor Supply has PHD for about $470 and 12 inch auger for $180. Given the number of holes I need to dig 650 to 700 is probably a pretty good price. Afterwards I could probably sell it on ebay
   / I need PHD #7
When I was looking for a decent PHD with a 12" auger, I had no luck at all finding a used one I could afford within 400 to 500 miles. My dealer sells Rhino, and used one of his stock units to dig two holes for a new sign he needed to put up. He couldn't sell it as new after that, so he put it in one of his quarterly auctions, and I got it for just a little more than I wanted to pay. So I now have a practically new PHD for a used or less price.
Point is, I would check with your local dealers, see what they might have available. You could luck into a bargain.
Good luck.
   / I need PHD
Eddie
Indeed I did got to Tractor Supply. Couple years back I was able to talk them into a discount on a bush hog and a tiller, but they would not come off the $700 (tax included) price for the post hole diggers and auger. Nine digs so far so I am at $78 per hole, and that will go down considerably with the projects I have over the next few months.
   / I need PHD #9
lakngulf,
Keep us posted on how the TSC PHD works out.
I was looking at them and not sure yet.
I like the ETA PHD, looks rugged, $760 w/6" auger, they claim heavy duty built.
Ltr
   / I need PHD #10
Recently I saw a Danuser F8 reconditioned for around $750. It is a brute of a pto PHD and cannot be stopped. At the moment I'm using one that my orchard buddies have loaned me and I can tell you it is a little bit of a hassle to hook up as it weighs >300#. Another thing I've found is that for my Landini Mistral 50 I cannot get 48 inch vertical clearance to do a vertical post but I am able to do a steep angle which is what I need it for. So depending on the tractor you're using and the weight of the PHD you might find some are better for your tractor and easier to get on. At the end of the day if I had some extra cash laying around I would go for a hydraulic PHD that I could put on my bucket. That way you get easy maneuverability, clearance out the wahzoo, easy angling, down pressure, and reversibility.
BUSH HOG 7007 LOT NUMBER 116 (A53084)
BUSH HOG 7007 LOT...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
ABI TR3 LOT NUMBER 147 (A53084)
ABI TR3 LOT NUMBER...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
