I think I might need pump CBN-E306L-X1
   / I think I might need pump CBN-E306L-X1 #1
gsdavis1
Cleveland, OHIO
John Deere 855
My 3pt. has been acting up. It stopped working about a month ago and I cleaned the filter and replaced the fluid, then all was well. Now again it stopped working altogether. I am thinking my pump may be bad. I have a Goldoni with a Shunde (Jinma) motor. I am not really sure how to check to see if the pump is bad. When I look inside the 3 pt resivoir, I can see fluid flowing through. The pump I currently have is CBN-E306L-X1.
Greg
   / I think I might need pump CBN-E306L-X1 #2
   / I think I might need pump CBN-E306L-X1 #3
Greg
The pump is the only thing that can make the fluid flow; however you can crack open a high pressure line and crank it over. If you have fluid squirting out, you got pump.
Could it be that the pump is not building enough pressure even though I see fluid running?
Greg
   / I think I might need pump CBN-E306L-X1 #5
How did the old fluid look? It could be that you have a clogged or possibly a collapsed line. Just a thought.
Steve
The fluid looked fine before. I think I am going to install an in line guage to monitor the pump. I assume I put in a pressure guage or maybe its a flow meter...I'm not sure.
Greg
   / I think I might need pump CBN-E306L-X1 #7
Pressure gauge to test pressure.. flow gauge to register gpm.. etc.
Soundguy
Well I finally figured it out. Had to take the whole thing apart, but a piece of linkage had come apart inside the valve actuator assembly. I guess the only good thing is now I know this 3 point hitch inside and out.
Greg
   / I think I might need pump CBN-E306L-X1 #10
Greg
Simple solution and cheap.
jb
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
