I thought curl was suppose to be stronger then lift?
   / I thought curl was suppose to be stronger then lift? #1
LittleBill21
Elite Member
PA
Mahindra Max 26XL, White
so I have been using a set of pallet forks (Bolt On) on my mahindra, what I find interesting, is that curl is weaker then lift, all the video i have watched the curl is suppose to be stronger, yet when picking up my land plane and some tree's i am apparently over the curl limit, but not over the lift, as I can lift the item, but not tilt it back.
any thoughts.
   / I thought curl was suppose to be stronger then lift? #2
Curl is measured at a specific distance from the pins, the forks are pushing the weight farther from the pins.
Also, it sounds like you're stressing the limits of your tractor. Not a good idea if you want to keep it for a few thousand hours.
   / I thought curl was suppose to be stronger then lift? #3
Mine has always been a little weaker on the curl than the lift. IIRC the curl cylinders are a little smaller than the lift cylinders, at least on my 2538.
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
CAT 420F2 IT (A50854)
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
