Milo
Platinum Member
- Joined
- Aug 7, 2006
- Messages
- 990
- Location
- Preston County, WV
- Tractor
- JD 3520, Ferris Z2100, Kawasaki Mule Pro MX, Honda Pioneer 520
Having a shop built with an insulated slab floor and the builders are about to dig for the footers. I drew it up using concrete block with 2" EPS foam up the stem walls and under the slab. The builder just mentioned he might just use ICF's because they do them themselves and finding block layers is always difficult. From what I've researched it seems reasonable, maybe even better. ICF's are available in a waterproof version also one that is resistant to termites, should I insist on those versions? One concern is the 6-8" exposed on the outside below the siding? Can't leave just the foam exposed need something over it to protect against UV, string trimmer, etc. Any suggestions to cover the outside ICF's from just below grade up to the siding?
