Identifying a wrench I found, yelllow CAT single box wrench?
   / Identifying a wrench I found, yelllow CAT single box wrench? #1
theriverman
California
72 Harvester
Does anybody know what wrench this is? Friend told me it probably is for a CAT. It's 16-1/2" length.
SEE pic.....;):confused:
   / Identifying a wrench I found, yelllow CAT single box wrench? #2
I have a glass bead blaster that will take that yellow and rust off in
two shakes of a lambs tail, but to answer the question it is called
a "box" wrench I do believe. :)
   / Identifying a wrench I found, yelllow CAT single box wrench? #3
Looks like an old CAT track wrench.
E/S
   / Identifying a wrench I found, yelllow CAT single box wrench? #4
Single box so you can easily use a cheater bar as long as you need to break the adjuster free.
   / Identifying a wrench I found, yelllow CAT single box wrench? #5
yep a factory wrench. With something large like that often MFGs included a wrench. Farmall F-20's came with a few wrenches. Our IH hydro 70 came with two wrenches, both single box ends. They are still in the tool box on the tractor.
i think its cool the equipment MFGs used to do that on a regular basis. Pretty rare now days.
   / Identifying a wrench I found, yelllow CAT single box wrench? #6
If is a Cat wrench there should be a part number stamped in the wrench, if there is let me know and I can check it out, work for a Cat dealer
Hose Reel (A55787)
Hose Reel (A55787)
2013 MACK CHU613 (A55745)
2013 MACK CHU613...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
