Ignition, Key Switch Question
   / Ignition, Key Switch Question #1
Piedmont3
Piedmont, OK
PT - 425
The Key switch on my PT-425 Moves. /forums/images/graemlins/frown.gif
It will spin when I try to start it or turn it off. /forums/images/graemlins/confused.gif
It doesn't move much, maybe 10 or 15 degrees of a 360 degree circle.
I took the plate off last night and tried to tighten it. /forums/images/graemlins/crazy.gif It was already tight, to the point that there are no more threads for the nut to tighten into. /forums/images/graemlins/frown.gif
Do I need to add a spacer of some sort to allow the nut that holds it tight to have more threads to use? /forums/images/graemlins/confused.gif
has anyone else had this problem?
If so, how did you fix it?
Thanks in advance for any suggestions. /forums/images/graemlins/smile.gif
   / Ignition, Key Switch Question #2
Sounds like there might be a missing washer that should go between the nut and the panel. Most switches that are designed to panel mount come with one, often in the form of a star washer.
I don't recall anyone else posting about this problem.
   / Ignition, Key Switch Question #3
Haven't had the problem on the PT but i have seen this before on these switches. Add the spacer or just back it off and slide something under it and tighten it back.
2018 Chevrolet Bolt EV Hatchback (A48082)
2018 Chevrolet...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
1269 (A50490)
1269 (A50490)
LEE G550 MOTORGRADER (A50458)
LEE G550...
2008 Cargo M1101 Trailer (A48836)
2008 Cargo M1101...
2024 KUBOTA KX080-5 EXCAVATOR (A50458)
2024 KUBOTA...
