ignition key
   / ignition key #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
Are the ignition keys on tractors truly universal? I parked my tractor in the front lawn knowing I was going to need it again soon so I took the key out. Now that key has vanished into thin air. I was wondering if those universal keys at TSC might work. The tractor is a Farmtrac 270DTC. The picture of the universal keys on their web site look similar but not exact.
   / ignition key #2
I would put a call into the dealer. There seems to be several variations of universal keys. If the key at TSC is for the Farmtrac then it most likely will work.
   / ignition key #3
I think the answer is "sort of." The super of a construction project I was visiting pulled out a ring of maybe two dozen keys and said that with them he could start most any kind of power equipment on the job site. That says there are a number of variations, but large numbers of common keys. I suspect that if a key is supposed to work with your model it probably does.
   / ignition key #4
JD is that way unless specified when buying.
   / ignition key #5
our two JD tractors have universal keys, the JD skid steer is unit specific
   / ignition key
THank you for the replies. I looked at TSC and their keys looked like the key for my Farris mower which did not work. LS is still using the same ignition switch so the dealer had them in stock.
SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
2010 Chevy Silverado HD Crew Cab (A52384)
2010 Chevy...
(miles exempt on title) year: 2010 Make: Chevrolet Model: HHR Vehicle Type: Multipurpose Vehicle (A51694)
(miles exempt on...
Year: 2017 Make: International Model: DuraStar 4300 Vehicle Type: Truck Mileage: 45,026 Plate: Body (A51692)
Year: 2017 Make...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
