Mowing IH 254 PTO question
   / IH 254 PTO question #1
duby13
Columbus, IN
None
Hello. I just picked up an IH 254 compact tractor. My question is on the PTO. According to TractorData.com, this model should have a live PTO. However, in practice, the PTO disengages when the clutch pedal is pressed all the way down. I had read that some machines used a dual clutch set-up, where you pressed the clutch down half way to disengage the transmission while the PTO kept turning. The only way the PTO would disengage would be if you pressed the clutch all the way down. I tried this on my tractor, and it did not work, as both the transmission & PTO disengaged & engaged at the same points.
Can anybody say for sure how this PTO is supposed to work?
Thanks.
Mike
   / IH 254 PTO question #2
It is working properly. Early tractors had ground driven PTO's which did not work unless the tractor was moving. Live PTO basically works with the tractor running. Pushing in the clutch is a safety feature so you do not either snap the PTO or possible engine problems if you need to quickly stop the PTO from spinning. Pushing in the clutch is easier than throwing out the PTO lever when in a panic mode if you hit a rock brushhogging or suck in a large clump of hay when baling.
2014 Chevrolet Tahoe SUV (A45336)
2014 Chevrolet...
2003 Chevrolet S10 Pickup Truck (A44572)
2003 Chevrolet S10...
300 Gallon Tote (A47809)
300 Gallon Tote...
Kubota 902 Diesel Engine (A47809)
Kubota 902 Diesel...
2007 Cherrolet Impala Sedan (A44572)
2007 Cherrolet...
Cincinnati number 3 mill and drill cutter grinder (A45336)
Cincinnati number...
