ih 420 baler
/ ih 420 baler #1
carasel
international 420 baler. i need to replace some pick up teeth. anyone know an easy way to change these out? i know(i hope) there is an easy way to get to the nut. being where the attachment nut is. i cant get a wrench on it except on the end teeth. thanks for any info.
/ ih 420 baler #3
There is no easy way. Just remove the belly bands. Sometimes,you can remove every other one and get access to the pickup teeth that need to be replaced. Ken Sweet
/ ih 420 baler
thanks guys! i understand the belly bands.
Art are the strippers the same thing?
/ ih 420 baler #5
Yes they are, that is the more technical term.
2002 Ditch Witch 1230H Walk-Behind Trencher (A61572)
2002 Ditch Witch...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
Kubota L2501 (A62177)
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
