IH 434 Glow Plug Indicator hot
   / IH 434 Glow Plug Indicator hot #1
monkeys
Hi all
Our IH 434 glowplug indicator has started glowing red hot and staying that way long after starting - any ideas of what's causing it? Wiring or glowplugs themselves?
cheers
Ian
   / IH 434 Glow Plug Indicator hot #2
See electrical circuit att
GLOW PLUGS ARE NOT AT FAULT !!!
Indicator not going off after starting and releasing heater switch is either due to switch stayin g on or an internal short in the harness giving a 12volt feed to the heater circuit.
  • 434 Electrics, Diesel & Glow plugs.pdf
thanks for the reply, although the wiring diagram is meaningless to me!! :)
Our tame tractor guy is coming out to fix on Monday, in the meantime I started it without the plugs this morning and all is good so may well be a sticky switch.
Cheers
Ian
   / IH 434 Glow Plug Indicator hot #4
Lets know what he finds ???????
Fire Place Mantel (A49462)
Fire Place Mantel...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2025 LandHonor DCM-11-250G Hydraulic Double Discharge Concrete Mixer Skid Steer Attachment (A49462)
2025 LandHonor...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
2025 LandHonor GM-12-96W Hydraulic 96in Grader Blade Skid Steer Attachment (A49462)
2025 LandHonor...
