Oil & Fuel IH 454 injector pump
   / IH 454 injector pump #1
MKS69
La Vernia, TX
I have an IH 454 with a Bosch injector pump. The pump is leaking from the top of the pump around the diamond shaped plate which I think is the advance housing plate. These are my questions.
1. Can I just replace the seal for that particular part, or is it a sign of a bigger problem.
2. If it's just that seal, is it something a novice mechanic can do.
3. What is the procedure for removing the pump and once it's replaced how do you prime it.
Thanks in advance for any helpful tips
   / IH 454 injector pump #2
Seen your post on the other forum, iwill get some info and reply to you on that forum ????
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2006 International 4400 LP Crew Cab S/A Heavy Haul Truck Tractor (A49461)
2006 International...
2013 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2013 MACK GU813...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
