Implement for removing debris from soil?
   / Implement for removing debris from soil? #1
jgibbens
Bronze Member
Hopedale, IL
Kubota BX 25D
I've heard that there is some kind of implement for removing debris from soil but haven't been able to figure out the right search term(s). My new property has a history as a dumping ground and there is a lot of broken glass/nails/??? mixed in. The soil here is mostly sand. What should I be looking for?
   / Implement for removing debris from soil? #2
If you are trying to clear trash of 2" or larger you can use attachments that are considered rock pickers such as rock buckets and some one is making a drum that rotates that separates dirt. For smaller trash you could try a soil conditioner also called a Harley rake that will rake the surface down to an inch or 2 and you can windrow the trash to pick up. Smaller trash like broken glass may be some thing that you have to pick up by hand.
   / Implement for removing debris from soil? #4
The beach cleaner is a great machine but there is a minimum horse power requirement and it needs rear hydraulics. It is also a very pricey machine.
Those beach cleaners look good for keeping the surface clean.
2019 John Deere 8270R Tractor  Front & Rear Duals, Rear Weights, Guidance Ready 7205 Hours (A46878)
2019 John Deere...
2012 Buick Enclave SUV (A46684)
2012 Buick Enclave...
2014 BMW 320i Sedan (A46684)
2014 BMW 320i...
2019 Ford F-150 4X4 (A48561)
2019 Ford F-150...
2002 Genie S125 125' Manlift (A45336)
2002 Genie S125...
2012 FONTAINE 53FT STEPDECK W/HORIZONTAL SEPERATOR (A47001)
2012 FONTAINE 53FT...
