implement help
/ implement help #1
roadhouse
can any one tell me the difference between a york rake and a cultivator as far as what they do or suposed to do?
/ implement help #2
I'm no expert roadhouse but a York rake is a 3ph landscaping tool that helps prep a smaller field/yard for seeding. It removes rocks and does minor grading.
A cultivator is an attachment that farmers use to weed a planted field of growing crops...there all set up a little different depending on what you have growing.
You can Google 'york rake' and see a youtube video of both implements in action.
/ implement help #3
A "york rake" is the same as a landscape or yard rake.
I don't know if that helps you at all, but I thought the clarification might be necessary.
/ implement help #4
Here're a couple pictures of an old style cultivator that was called a "soil ripper", which it can do. My 18.5 hp 4010 will pull this thing like the old 18 hp JD M used to do, with the "cultivator" tines buried.
Agri Supply has a frame on which you can attach either cultivator tines or disc hillers. It's called a Keulavator. I've disc hillers I can put on mine. I can even put a combo of disc hillers and tines.
Ralph
/ implement help
i think a york rake is what im looking for, thanks for the clarifacations, and the responses
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2011 KUBOTA KX121-3ST SUPER SERIES EXCAVATOR (A64279)
2011 KUBOTA...
KBH Tank Trailer (A63688)
KBH Tank Trailer...
Atspower Mini Excavator (A60352)
Atspower Mini...
