IMT 533 oil leak at a tiny hole below clutch chamber
   / IMT 533 oil leak at a tiny hole below clutch chamber #1
MERVYN PERERA
Kurunegala,Sri Lanka
IMT 533
My old IMT 533 having a problem leaking oil through a tiny hole below the clutch chamber.Is it due to a damaged oil seal?
   / IMT 533 oil leak at a tiny hole below clutch chamber #2
Most likely, that hole is called a weep hole and it is there to let any leakage drip out so that the clutch does not end up submerged in oil.
Aaron Z
Thank you sir,Is that urgent to attend the leakage?
   / IMT 533 oil leak at a tiny hole below clutch chamber #4
First ....check gearbox dipstick for the color of that oil and compere it with the oil out of that weephole aswell with your engine oil. That wil give you an idea of what oil is leaking
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
