In expensive UTV plowing lights
   / In expensive UTV plowing lights #1
DIXIEDOG
Platinum Member
Maine
International 2544 / Gator 825i/L2501/General
I recently installed a Boss V-plow on my Gator 825i to get it ready for plowing season, I noticed due to the very high plow height my stock headlights will need a bit of help for when I'm plowing this winter. What are some decent work lights that won't break the bank that would work well for plowing when mounted up on the roof?
   / In expensive UTV plowing lights #2
The Boss light kit isn't too expensive, I was quoted under $200.
Have you seen the Boss light kit? I've heard mention of it but haven't seen it yet, I thought about that as a solution as well. The only other concern I have is I believe they mount in the push frame on front of the Gator which would put them in a pretty vulnerable location for when I'm out four wheeling. I'll have to do some more research and see if I can find a set installed to look at. Thanks for the suggestion.
   / In expensive UTV plowing lights #4
I'm about to place my order with the light kit, I'll post pics when I have it set up.
Matt
2005 Hummer H2 4WD SUV (A50324)
2005 Hummer H2 4WD...
Kubota L2650D Compact Tractor w/Loader (RUNS) (A50774)
Kubota L2650D...
2022 Mack MD Danco 12R22 22FT Rollback Truck (A50323)
2022 Mack MD Danco...
Unused 2025 CFG Industry MX12RX Mini Excavator (A50322)
Unused 2025 CFG...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
John Deere 7130 (A50120)
John Deere 7130...
