Injector service?
   / Injector service? #1
wanasrx
Bronze Member
NY
Kioti 3054
Do the diesel injectors need regular service or rebuilding/new at any point? If so, is this something for the dealer to fix?
   / Injector service? #2
If they aren't broke don't fix them... best advice I can give... and oh ya... run some diesel conditioner though your system, this is also good for cleaning injectors as well as the fuel system....
   / Injector service? #3
I see PS diesel fuel conditioner for sale at Walmart. Is this recommended or needed for the Kioti diesels?
Good, clean, fresh, fuel is a given.
   / Injector service? #4
Power Service is good stuff, it sure won't hurt anything to use it. It is good for any diesel regards what brand....
   / Injector service? #5
I would harbor a guess not any dealers are set up to actually refurbish diesel injectors. The would likely send them out to a diesel injector/pump rebuild shop for that. It takes much expensive specialty equipment for that.
In Seattle area we have Seattle Injector.
Maybe someone can recommend an outlet near you.
Usually one doesnt rebuild injectors unless theres a smoke problem not related to compression or timing, or a miss not related to compression or pump output. Or its stuck wide open.
PowerService fuel additive is good insurance.
2013 Jeep Patriot (A50324)
2013 Jeep Patriot...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A51244)
UNUSED FUTURE MINI...
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
2010 Ford F-150 (A50323)
2010 Ford F-150...
91013 (A48082)
91013 (A48082)
