FN in MT
Bronze Member
The clutch on my new 2620 has started to simply NOT work upon start up. I'll pull the tractor out...then go to engage the rear PTO and ....no clutch. The pedal pressure is also higher than when the clutch works regularly. I've checked all the linkage, as well as the hyd fluids. All OK.
Today it finally started to work as normal after several minutes. And the pedal pressure was back to normal as well.
I have read that the clutch can STICK. Hence the little wooden block supplied with the tractor. Mine set for a week maximum. Maybe I simply need to install the block to keep the plate away from the flywheel??
FN in MT
FN in MT
