Instaling a BHT-1 Moisture Tester
   / Instaling a BHT-1 Moisture Tester #1
xcsp
Bronze Member
Berlin Center,Ohio
New Holland TN-55
I am Instaling a BHT-1 Moisture Tester Baler Mounted on my New Holland 565 It says to mount Locate a fl at spot between 12 to 24 from the rear of the chamber, about
halfway up the side, on the UNCUT SIDE of the chamber
NOTE: Readings from the cut side of the bale will result in greater
variations of readings and overall higher readings.
which side is the un-cut side of the baler ??????
Thanks Greg
   / Instaling a BHT-1 Moisture Tester #2
I would say the side opposite from the feed/pickup since that is the side the cutter is on.
Thanks for the help hopefully get to use it next week if the rain will quit
Greg
2001 INTERNATIONAL 4700 (INOPERABLE) (A50854)
2001 INTERNATIONAL...
2018 Ford F-150 (A51039)
2018 Ford F-150...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A51222)
2020 VOLVO...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2011 Cadillac SRX LUXURY (A50324)
2011 Cadillac SRX...
