teeravis1
Guys I have been trying to get my new 60" mmm put together and installed since saturday morning. I didn't feel the book was very good, I spent about 12 hrs on it saturday, 2 hrs on it yesterday and am not done yet. Anyway I did get it put together now and I do have it installed on the tractor, so hear are the things I need help with.
First one is a goofy one:
1) The stop bolt for the spring on the grass chute you bolt down thru the chute and the deck - is it necessary to install because the holes on the deck and the chute don't line up. Also they gave me a 30 mm not a 25 mm bolt like called out in the book. Don't know if it matters, I guess the real question here is can I not put that bolt in since it doesn't line up. I don't understand its purpose anyway to be honest with you.
The more important questions:
2) The the way my front link sits in the front bracket of the mower deck I'm not sure it is correct. I have measured and adjusted both sides of the front link to be the same length as the book says. The book says to adjust them to 19" 11/16", I got them adjusted to 19" 9/16" because if I made them any longer they wouldn't fit to lock in when you close the handle thing on the front. Anyway when I have the gront link installed and the deck is all the way down, or up as high as I can put it the welded pins on the front link sit unevenly in the bracket. There is more space between the end of the groove in the bracket and the welded pin on one side than the other. Is this normal?
3) I have a B3030HSDC, do I have to remove the step? If I would of listened to the book and went up into the tractor and lifted the mower deck all the way up like it says I would have smashed my step right down into one of the belt covers on top of the deck. So do I have to remove the step, or am I suppose to adjust the connecting rod lengths to be longer so I can raise it up all the way and then adjust the distance between the tractor frame and the mid and rear stops on the deck ? Right now I have the connecting rods adjusted to what the book says.
4) There is a spot in the book where it says to level your 3 point hitch arms and set your stop for the lever at that spot so you can't put your 3 point any lower. My question is ...is that the mowing position? or are you suppose to mow with the deck all the way down? Is the center rear gauge dual wheel suppose to be on the ground or off the ground when you mow?
Any and all help would be appreciated, I was hoping to be mowing by saturday, not quite working out
Thanks everyone, I reallly appreciate being able to get out on the net and have some place to ask questions and get answers when you are really in need of them - Thanks Again.
