Installing a glow plug dash light on 2010 GC2400
   / Installing a glow plug dash light on 2010 GC2400 #1
Dmacleo
Veteran Member
Etna, Maine
2010 MF GC2400 Owner, 2012 MF1532 User
anyone try this on a GC24xx series?
EDIT:
see below. mine has bulb, dash display, no wiring from plugs to dash.
huh my dash has a LOT of unused bulbs in it, you shine light through and stuff like 4wd engaged sign, glow plug sign, 2 pinkish battery signs,headlights on sign, 4ways engaged sign.....yet the wiring schematic and electrical section of service manual do not mention them.
wonder if I can utilize that somehow.
edit:
yeah I got a LOT of pins on dash that have lead to blank spots on the round wiring harness connectors. so I think I will find what pin the glow plug light uses and insert a pin connector into the round dash connector and run wire to the buss for plugs.
   / Installing a glow plug dash light on 2010 GC2400 #3
You mean they STILL don't have a glow plug light???
mine is a 2010 GC2400.
I know 2021 GC1725M DOES have it and I BELIEVE the 2020 and 2021 GC1723 has it, I just cannot remember.
just odd how mine has (iirc) 5 bulbs sitting behind labeled "lenses" with all the circuitry down the the round multi pin connector YET the tractor side of connector only has 3 or 4 pins in use on each side. ground, right turn/4way, oil (iirc) on right connector and ground, left turn/4way, battery on left side connector.
should be faily easy to find what pin on the board goes to the bulb I want then just put an insert into the tractor side connector and run wire to the buss connector. would fuse it to be safe of course.
   / Installing a glow plug dash light on 2010 GC2400 #5
This is what I did for the glowplug lights on my 2009 GC2410.
See post #3 of the "GC Series Owner Upgrades And Modifications"
#1) My first best cheap upgrade to list is because of ray66v great idea, and I urge everyone to INSTALL A GLOW PLUG ACTIVATION INDICATOR LIGHT to light up when the glow plugs are activated, 👍.
I purchased a sealed 1/2" diameter red light from Napa and installed it in the dash near the emergency switch. I looked under the dash to make sure there was lots of room where I drilled the 1/2" hole with a flat style wood bit through the plastic dash. The location is approx 3/4" to the left of the emergency switch and approx 3/4" lower then the emergency switch, :cool:. I connected a red and black 20 gauge wire (enough plus a little extra to make my connections) with crimp style connectors and installed heat shrink tubing to the two black wires extending out of the back of the light. I then added a 1/4" slit wire loom covering over the two wires. I fed the wires and loom through the hole I drilled and pushed the light untill it was flush with the outside of the dash and made a label to identify the light "GLOWPLUG LIGHT". I connected the black wire to a grounding 1/4"-20 bolt with a crimp style connector along with heat shrink tubing near the back of the dash and the ground side of the battery (this bolt was installed for the horn ground I had installed at an eariler date). I then fed the red wire and loom and connected it the glowplug wire on the flat metal bus bar plate that connects all three glow plugs, again using a crimp style connector and heat shrink tubing, ;). Now I can "see the light" when the glow plugs are activated, :cool2:.
Hope this help you,
KC
Hope this help you,
KC
did you find yours HAD the glow plug dash light but not hooked up?
thats what I have, that and other things that are there just no wiring from tractor side to dash.
I may also hook up the lights on dash indicator.
no way I can do the 4WD engaged or PTO engaged (no real need....its easy to tell it is LOL ) lights as no switches in unit itself
   / Installing a glow plug dash light on 2010 GC2400 #7
I did not have any nonworking lights on my dash, MF must of started that in 2010.
KC
KC
yeah I figured was a year issue and where yours a 2009 figured I'd ask to narrow that break point down.
when I get chance to do this I'll post the pins used.
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2019 Ford Transit 150 Cargo Van (A48081)
2019 Ford Transit...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
2016 Nissan LEAF Hatchback (A48082)
2016 Nissan LEAF...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A48082)
2009 Skeeter SL190...
2022 Club Car...
