Installing a heat temp oil filled gauge on JD 950
   / Installing a heat temp oil filled gauge on JD 950 #1
bnlake
mansfield,ga
john deere 950
Thought I would move this to the JD Owners.
Hi,
I had my john deere 950 rebuild finish and running like a kitten, I wanted to add a heat temp gauge oil filled to the tractor instead of the light indicator, I'm having trouble finding a a fitting to connect the gauge to the block where the temp sensor was removed. I'm guessing right now that the threads on the temp sensor is 14mm (can't get an answer from JD dealer ) The gauge I have found so far is a 1/2 inch npt. Any thoughts as to where to find a fitting or another idea on how to attach an oil filled temp gauge to this tractor ? #2 If I use an adapter on the block do you think the probe will be out far enough?
Thank you
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A56858)
2008 Ford F-550...
40006 (A55788)
40006 (A55788)
2014 Jeep Cherokee Sport SUV (A56859)
2014 Jeep Cherokee...
