Instant reverse sump
   / Instant reverse sump #1
jfharper
On my MF 205 industrial, I took my oil sump and screen off today and noticed there were two grooves it looks like someone ground out with a wheel grinder in order to connect the two reseviors for the clutch area and gear area. Are these supposed to be connected this way.
I looked in my manual and the only thing it says is the fluid is the same for the internal hydraulics, transmission and differential which is a combined 8 US gallons.
I know the rear internal hydraulics chamber and gear area of the transmission are connected by little holes, but I didn't know if the clutch pack area is supposed to be all connected. The clutch pack area has a pump on the front which sucks up oil from the sump and into the clutch packs...I think it also feeds the torque converter.
But, I don't know about this sump connection. There is a wall separating the two resevoirs, but I wonder if there were two grooves already, and someone just made them larger. Anyone know?
The manual doesn't specify if the clutch area is supposed to separate fluid, even though it is the same type of fluid.
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2005 TerraGator 8104 (A53473)
2005 TerraGator...
2018 FORD F150 XL TRUCK (A51406)
2018 FORD F150 XL...
Dual Bathroom Mobile Toilet (A51691)
Dual Bathroom...
1964 Mercedes-Benz 190D Collectible Car Sedan (A51694)
1964 Mercedes-Benz...
