Backhoe Instruction Sticker for removing B21 backhoe bT751
   / Instruction Sticker for removing B21 backhoe bT751 #1
BruceWard
Platinum Member
Central, AR
I have been trying to figure out how to removed the backhoe on my B21. I noticed that a worn away sticker contained partial instructions. A local rental place let me take pictures of the instruction sticker on their B21. I hope this will help others.
Removal
Installation
From the instructions it sounds more convienent than BX backhoe removal since the hoses are long enough to be connected while the backhoe is sitting on the ground.
   / Instruction Sticker for removing B21 backhoe bT751 #2
Bruce it is really very easy once you do it a couple of times. A couple of hints before you try to do it. Alway set the backhoe on level ground when you remove it. It can be difficult to reattach if sitting on an angle. Get some oil on those release levers, they can freeze up when the backhoe has been on for years without removal. Don't forget to reset the hydraulic diverter valve to make the 3pt. hydraulics work, the lever on the right of the seat that pulls up and down.
MarkV
2023 John Deere 8R410 MFWD Tractor (A52128)
2023 John Deere...
2015 DODGE RAM...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2008 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2008 CATERPILLAR...
