int 434 oil change
   / int 434 oil change #1
pvcman1
bridge lake bc
mccormack international434
Hi, going to be changing the transmission oil on my international 434 tractor,the info i have says it needs 4 3/4 gallons of oil does this sound right? also it says fill up to oil level plug does this mean it will be filled nearly to the top? Thanks.
   / int 434 oil change #2
the oil level check plugs in most trac tors are SELDOM ever near the top. Some might make it half way.. usually just under half.. that way things like pto, axle, and input shaft seals aren't submerged in oil full time...
   / int 434 oil change #3
Looks like the check plug is on the right side, the top #6 in the exploded view. The bottom #6 would be the drain plug. Part description is for both, being a 1/2" pipe plug. Official Case IH Online Parts Store and Case IH Catalog for Best Parts Search and Best Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts
Most generally, the oil check plug is just below the level of the transmission main shaft, and/or PTO shaft. Depending on if the plug is fore, or aft.
2025 Wolverine EX-66-84L Pallet Fork Extensions (A47484)
2025 Wolverine...
2025 Wolverine ADB-13-1218R Auger Attachment (A47484)
2025 Wolverine...
2025 Wolverine PFA-11-3300G Hydraulic Pallet Fork (A47484)
2025 Wolverine...
2025 Wolverine EX-66-78L Pallet Fork Extensions (A47484)
2025 Wolverine...
3000 Gallon Black Poly Water Tanks (A45336)
3000 Gallon Black...
New Holland 256 Side Delivery Rake (A47484)
New Holland 256...
